Allowable Stress Values
Does anyone have access to the Allowable Stress Tables in ASME Sec. 2D? I am trying to locate the allowable stress for SB-168 N06600 in order to accurately calculate the Tmin. values for a pressure vessel.
RE: Allowable Stress Values
Mike
Now, if one is performing a FFS approach, that's a bit different, though similar.
Better to have the required thickness determined in the design phase than to try to figure it out after the vessel has been in service. This is relatively easily done, and reduces the number of issues that could come up later.
Often any excess material present in the shell material is utilized in the calculations for nozzle reinforcement. So, t.nom-CA is often accurate in areas around nozzles.
