looking for large heavy turning capability shop
i'm located in west central ohio, and i need to find a company that can turn a journal of approximately 30" diameter on one end of a crosshead-stalk guide assembly for a 4000 ton forging press.
we had planned to have this onsite machined, but now we have decided to remove it and send it out for machining.
this piece resembles an inverted "T". the base is 11'x 2'4"x 3'6" high. the stalk is approximately 30" in diameter central to the base and the overall height including the base is 16 ft.
this piece weighs 64000# and is a steel casting.
can anyone point to a machining facility that can handle this close to the lima ohio area?
thanks
bobc
RE: looking for large heavy turning capability shop
Speak with Walt Wardley at:
Bosma Machine & Tool Corp.
4754 East U.S. 40
Tipp City, OH 45371 9400
USA
Tel: 800-745-4004
Fax: 937-667-5864
http://www.bosma.com
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
thanks david, but this is too large for bosma.
they did however lead me to dynamic in cincy, and it looks as if they have the capability.
thank you,
bobc
You might want to try www.MfgQuote.com.  You can post your requirement and shops with the capabilitly and capacity will provide a quote to you online.
Try this.. look at the web page..
contact...
David F. Myers
Magna Machine Co.
11180 Southland Road
Cincinnati, Ohio 45240
Work PH. 513-851-6900
Work Fax. 513-851-6904
Web Site http://www.magna-machine.com
e-mail dmyers@magna-machine.com
I have a client that can handle this.  They are frequently involved in turning large shafts for the steel and large press rebuilding industries. They are located south east of Cleveland. If interested contact me @216-272-3292, John W.
i have received a quotation from dynamic machine in cincy. he is very confident he can handle our project.
i am still researching others, and am waiting to award the job.
thanks to all,
the clues pushed me in the right direction.
bob creely
Try
Jeff Zombar at ADS Machinery Corp
330-399-3601 x 244
zombarj@adsmachinery.com
I believe they may have the capacity you are looking for.
Best regards
Ant101
True circle engineering in wichita Kansas.They can handle anything up to 180 inch diameters.
