How to set a position-dependent Body Force in Ansys?
Hi to everyone,
I would like to know how to set a body force which depends on coordinates. I give you an example:
My domain is a free cylinder, but instead of a body force as gravity (which has the same value at every point of the volume), I want to set a body force which depends on the radius distance, F = A*r^2 (F will be 0 in the z-axis and maximum in the cylinder maximun radius). I also remind that r=sqrt(x^2+y^2)).
Then, summarizing:
1.- How should I set volume/body forces?
2.- How can make this body force position-dependent?
Thanks.
Then, summarizing:
Thanks.
RE: How to set a position-dependent Body Force in Ansys?
Do you agree with this solution?
Thnaks for your suggestion.
If only the initial position should be used, then it can be directly done in preprocessing with Abaqus/CAE.
If the load needs to be updated during the analysis (because of deformation, e.g.), then a Fortran subroutine can be created to do it.
