Desing of Purlin to AS4600
Hi
I am trying to desing a purlin using the AS4600 I for a diffrent results than the Prulin manufacture specially for diffrent bracing length
I got teh section capacity correct but the issue witht the reduction of capcity to member length does any one know a sloved example or commetry to explain the used numbers
RE: Desing of Purlin to AS4600
Yes you are defiantly wright I end up to same results but why they do not state this in their data sheets to save time of checking and they should also provide a way for specific design
http://professionals.lysaght.com/sites/default/fil...
