CATIA V5 macro, how to get the current activate sketch
Before a macro program begin running, a sketch has be opened. My problem is that how can I get the name of the sketch, and its parent object? In many examples, we use sketch.add(),or a certain name of sketch. But in different situations the opened sketches may have different names.
Any one have faced such problem ?
RE: CATIA V5 macro, how to get the current activate sketch
When then OpenEdition method is called on a Sketch object, it is made the InWorkObject. You can use the InWorkObject property of Part object to retrieve the Sketch feature and access it's Name property.
--Doug
Thanks for your suggestion, But I use inworkobject only get the hybridbody under the part,still not get the opened sketch.
or without user interaction:
CODE --> code
Sub CATMain()
CATIA.StartCommand ("No 3D Background")
CATIA.StartCommand ("Fit All In")
Set oSel = CATIA.ActiveDocument.Selection
oSel.Search ("Sketcher.Origin,scr")
Set oSketch = oSel.Item(1).Value.Parent.Parent.Parent
oSel.Clear
MsgBox ("the sketch is " & oSketch.Name)
End Sub
I'm searching for the Origin so it should be quick, but it should be visible, if not, then search for element type you know is visible then get parent until you get sketch.
Eric N.
