HITACHI SEIKI 2ML VERTICAL MILLER
I am having problems with the hydraulic clutch, whenever it is put into feed on any axis it doesn't engage. It will move in rapid and manual but not normal feed. If anyone has any ideas or hydraulic drawing please let me know
regards
Alan
RE: HITACHI SEIKI 2ML VERTICAL MILLER
You might have more luck on this forum: http://www.practicalmachinist.com/
Either here or there, though, you will get a lot more help if you give more information about your problem.
The way you asked it, your questions can only be answered by another owner/user of a similar Hitachi mill.
A description of what you've done already to diagnose/solve the problem will allow a much wider audience to help you.
STF
