Copy from a search and paste on first selection
I have a first selected item.
Then i perform a search-select-copy in the whole document, i copy, and i would like to paste in the first selection, but i cant find the metod
to recall the first selection.
Sub CATMain()
Dim objSel As Selection
Dim objSel2 As Selection
Set objSel2 =CATIA.ActiveDocument.Selection
Set objSel =CATIA.ActiveDocument.Selection
objSel.Search "name=*ITEMTOCOPY*,all"
objSel.Copy
End Sub
I NEED TO PASTE THE objSel in the objSel2
Sorry for the noob question :) !
RE: Copy from a search and paste on first selection
dim myfirstselectionobject
set myfirstselectionobject = catia.activedocument.selection.item(1).value
dim objsel as selection
objsel.copy
objsel.clear
objsel.add myfirstselectionobject
objsel.paste
Eric N.
Great, this code is indeed working. Though i have a small issue.
Sub CATMain()
Dim myfirstselectionobject
set myfirstselectionobject = CATIA.ActiveDocument.Selection.Item(1).Value
Dim objSel as Selection
objSel.Search "name=Pal_DX,all"
objSel.copy
objSel.clear
objSel.add myfirstselectionobject
objSel.paste
End Sub
If i play this the first time, this is working without any problem. The second and thirtd etc.. the Pal_DX is copied multiple times.
What i should tell the program is to copy or paste just the first result of the selection. I think the item(1) pointer should be added somewhere.
well if you have one Pal_DX before first run, you have TWO after first run , FOUR after second run...remember COPY paste
unless you rename the elements after paste them...
Eric N.
Is it not possible to tell the search command to take only the first item on the search array? The first copied-pasted item is in the Detail sheet, maybe this is helpful?
But i think is easyer the first metod. I think is the Item2 command i am searching for. Though i cant understand it's using.
Here we go... is here any improvement i can make to the code?
Sub CATMain()
set objSel2 = CATIA.ActiveDocument.Selection.Item(1).Value
objSel.clear
objSel.add objSel2
objSel.copy
objSel.clear
objSel.paste
End Sub
