Deep Foundation Software
Which software do you use (when you use) for piled raft foundations?
I usually work with structural engineer for iteration of pile capacities, they use SAP, ETABS etc. If I am alone in the design, I usually go with hand calculation, however, calculationg pile-raft load sharing ratio is not an easy job. If you do not use any software, do you just ignore raft capacity? I would love to see some of your reports.
In short: Which softwares for piled rafts?
