Bushing installation with sealant.
I would like to install bushing with sealant per BAC 5435 which requires sealant having a continuous line (squeeze-out). Fairing-out of the squeeze-out is optional.I would like to know what is the definition of “Fairing-out”. Does it means to make to make squeeze-out more smoothly by tool.
Thanks.
Thanks.
RE: Bushing installation with sealant.
STF
The ring of sealant between the ends of the bushing and the surfaces surrounding the hole not-only verifies the integrity of the wet-seal installation [100% moisture resistant], it also minimizes the effect of electrolyte [moisture] bridging across the metal surfaces [which are usually dissimilar]... by tiny droplets or thin-films that may form.
Regards, Wil Taylor
o Trust - But Verify!
So the point is that I have to make sure there are no any gaps between bushing and housing to avoid corrosion.
