Why can't I manipulate parasolid geometry?
Probably a dumb question, but why can't I do simple things like trim/unite geometry from a parasolid? I can't even export it to .prt as it won't highlight when I try? Are they technically sheet bodies instead of a solid is that why?
-Xh
-Xh
NX 10
RE: Why can't I manipulate parasolid geometry?
www.nxjournaling.com
The list will tell what type of objects you have. ( solids / sheets etc)
You should be able to export, no matter of the type.
Can you press "Ctrl+I" ( information - Object, hidden in NX10... ) and then select the object ?
can you snap a endpoint ? - Try Information - Point and snap an endpoint.
What NX version ?
Tomas
Name 1745-WFEEDERS_ID10_X_T
Owning part P:\................................................\-wfeeders_x_t.prt
Comp member in part P:\..................................................\wfeeders_id10_x_t.prt
Layer 1
Type Component
Color 134 (Medium Royal)
Font SOLID
Width 0.70 mm
Modified Version 1 04 Oct 2016 10:19 (by user kxh03)
Created Version 1 04 Oct 2016 10:19 (by user kxh03)
Actual Color 134 (Medium Royal)
Component Reference Set Name None
Component Translations:
Delta X = 0.000000000
Delta Y = 0.000000000
Delta Z = 0.000000000
Component Rotations:
X-axis Vector XC = 1.000000000 X = 1.000000000
YC = 0.000000000 Y = 0.000000000
ZC = 0.000000000 Z = 0.000000000
Y-axis Vector XC = 0.000000000 X = 0.000000000
YC = 1.000000000 Y = 1.000000000
Z-axis Vector XC = 0.000000000 X = 0.000000000
ZC = 1.000000000 Z = 1.000000000
Component is Unconstrained
Object dependency information is unavailable.
INTEROP_FEATURE_LAST_UPDATE_GMT = 4-Oct-2016 17:12:49 (String)
INTEROP_FEATURE_PART_NAME = solid (String)
INTEROP_FEATURE_AUTHOR = Parasolid (String)
INTEROP_FEATURE_ID = solid (String)
NX_MaterialMissingAssignments = TRUE (String)
NX_MaterialMultipleAssigned = FALSE (String)
NX 10
NX 10
1) File-Open- type= parasolid
and
2) File - import - parasolid
If the parasolid file has "structure", ( = is an assembly) method 1 will recreate the assembly, whilst method 2 will import everything into the work part.
- the structure will disappear. all bodies will be in the work part.
Tomas
