Trim 13%Cr+HF and Trim 13%Cr+HFS
Hi
As per our PMS the trim is 13%Cr+HF but vendor offer 13%Cr+HFS. I want to know is both material are same or is it Trim 5(13Cr%+HF) and trim 8 (13%Cr+HFS).Plz help for a solution for this.
RE: Trim 13%Cr+HF and Trim 13%Cr+HFS
www.australianpipelinevalve.com.au/lib/Pdf/Trim_nu...
HFS is Hard Faced Stellite with Stellite being trademark for Co-Cr as per Note g of API 600 Table 8.
The difference between 2 offers is one is Stellited.
Anyone else?
when trim(Wedge, Seatring,...) is 13%cr+Stellite in specification, I do not know base material should be 13%cr and we must apply an overlay welding by stellite? or only base material can be A105 and two layer must be applly with 13%cr and then Stelllite after that?
please help me
thank you all
http://www.eng-tips.com/viewthread.cfm?qid=244826
