Export the generated mesh to ETABS
Hi all,
I am using RAM CONCEPT 5.0.1 to generate the mesh of the plan, to use it in ETABS 9.7.4 I couldn't find a direct exporting option ...
So how can that be done ?
Thanks in advance
Thanks in advance
RE: Export the generated mesh to ETABS
Be sure to clarify the layer of the mesh in AutoCAD, so when you import into ETABS it recognizes it as slab and automatically assigns it a slab section.
