Copy sketch from draft to model
Hi All,
I've made a layout in the drafting environment. How can I copy and paste this layout into a model sketch ?
Lars.
Lars
Solid Edge
Inventor
NX10.0.3.5 native
RE: Copy sketch from draft to model
I don't think that copying drafting sketches and pasting into a model sketch is supported. One possible work-around would be to export a CGM of your drafting sheet, switch to modeling and import the CGM file, then create a new sketch in modeling and use the "use existing curves" function to get the curves into the sketch.
www.nxjournaling.com
You can do this if you created your 2D sketch in NX Layout. Don't know if this is already available in NX10 ?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
