DEFFERENT BETWEEN TYPEGRADE A & B 0F PIPE
HI .MY FRIENDS
PLEASE HELP ME FOR THIS QUESTION:
WHAT IS THE DEFFERENT BETWEEN TYPEGRADE A WITH B 0F PIPE STEEL?
THANKS A LOT.
THANKS A LOT.
QCR
RE: DEFFERENT BETWEEN TYPEGRADE A & B 0F PIPE
Please don't use all capitals. It's interpreted as SHOUTING!!!
You need to know what steel you're talking about API??, ASTM ????
Then look up the properties for that grade and type of steel.
If its API 5L,grade A is a lower SMYS than Grade B(35,000 psi).
Also look at ASME B 31.3 - you'll find most of the data you want there.
Higher Yield Strength will result in a thinner calculated wall thickness.
