Compressive strenght of interaction property
Is it possible to assign compressive strength to a contact between two surfaces?
With damage property for contact I have defined normal (tension) and shear strength, but I don't know how to add compressive strength.
For normal behavior I have used hard contact, but I would like to have the same behavior for compression as for the tension. That means to have some compression capacity and then when it is lost to have hard contact between these two surfaces.
Any advice?
Any advice?
RE: Compressive strenght of interaction property
Tsur G., Medinol.com
Have you considered Gasket elements?
