Grounding calculations
Guys,
I have two soundings from field (perpendicular to each other) and each of them gives one soil model for designing grounding grid.
I designed my grid based on first Grid and made sure it works for the second soil model too. Do you think this is a good approach or I should combine the data from two soundings?
RE: Grounding calculations
I don't know what a sounding is but am I guessing you mean wenner measurement and they are 90 degrees to each other. I would just design the grounding grid conservatively.
I think your approach is good. You can't always tell which reading is the most conservative, but I'd try the one with the higher resistivity in upper layers as the one on which to base the initial design.
