Star
RE: Star
Your solution is invalid since it implies that the two R2's are the same length and it's obvious from your diagram that they are not. Also, to what purpose are the R1's? They look like they play no role whatsoever in the answer.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Star
I'm afraid the contruction is indeed incorrect (though R1 does play a role, it is to find R/2).
R2 should be the side of a pentagone, in that case its value would be R2=2R sin 36°=~1.176 R
But from the construction R2=√(R2+R2/4)=~1.118 R
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
RE: Star
Yea, that works pretty good...
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Star
My error... left out a step.
RE: Star
I'm still not completely convinced what's the significance of the two 'R1' radial curves, unless their only purpose was to help find the mid-point of the horizontal line from the arc's center to its perimeter. So if that IS the case, then their lengths, 'R1', has NO relationship whatsoever to either the values of 'R2' and 'R3', correct?
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Star
Bingo! Now it's exact.
As before R2=√(R2+R2/4)=R√1.25
Now R3=√(R2+(R2-R/2)2)=R√(2.5-√1.25) and this is exactly 2R sin 36° !
However I admit that this is not a very elegant proof, another one based on pure geometry would be much better.
RE: Star
That's correct, John. R1 is to determine the bisector of the line.
Dik
RE: Star
It's a classical Euclidean geometric proof, i.e. you need to prove the solution using only a straightedge (no markings allowed on it) and compass.
RE: Star
Of course with today's CAD packages, these sorts of things have trivial solutions when using their 2D sketch tools with a constraint-solver. BTW, this is how I would approach the problem of the two-ladders in an earlier 'Brain Teaser'.
Irvine, CA
Siemens PLM:
UG/NX Museum:
RE: Star
maybe I'm dumb today but why does R3=2*sin36deg make it so ? don't we need the vertical distance of the R3 intersect with the datum circle ? (=x, then cos72 = (1-x)/R3)
RE: Star
yes, I was dumb, but today I did some thinking and realised ... look at the centre !
RE: Star
A 5-pointed star (pentagram) is a trivial variation of a pentagon.
Euclid's Method on Wiki with Animated Gif
Now that we've all finished inscribing our pentagrams, how long until somebody starts screaming "Witches!! Witches!! Witches!!" ? smile
RE: Star
"witches?" ... "burn 'em!"
RE: Star
But how do you know she's a witch?
RE: Star
She's got a wart!
RE: Star
She turned me into a newt
RE: Star
I got better.
RE: Star
what do you do with witches ? (we can keep this going for weeks !)
RE: Star
Yes, but I don't have to look it up, I've memorized the entire dialog. I've got a book of the screenplay which starts off in typical Python fashion with something completely different.
What a complete waste of my remaining brain cells!
RE: Star
Always wondered...why the focus on pentagrams, when witches were supposed to put hexes on people?
