Inspection Chamber at every Joint
Dear techies, I have attached a pic of commercial sewer drainage line. Here the designer put Inspection chambers at every joint or junction. He put chambers at even 1.5mts distance which is just weird.
I don't think this as proper way. If we keep adding IC at every joint and junction the whole lane will be filled with ICs. Isn't there other option to this. Like I think we can omit the ICs by joining the incoming pipes with two 45 degree elbos. ICs should be added every 20mts.
RE: Inspection Chamber at every Joint
f-d
ípapß gordo ainÆt no madre flaca!
Just raise the question with the designer. Or if you know someone in the local council/authority, ask them if it is permitted to connect directly to the line without an IC. Note : that it would be advisable to include a vertical rodding eye detail on the line (if not going to an IC) before it connects to the main line.
