Trends Seen from Trade Shows
I was in China last week at a small trade show focused on metal industries. Voith made a presentation about controlling hydraulic actuators directly with pumps with out valves. Several different options were presented. The simplest and probably the best they called a CLDP or closed loop differential pump where one motor ( VFD or servo ) controlled two pumps. Each pump is sized in proportion to the surface areas on the cap and rod side of the piston. The position control seemed to be poor though as shown by the Voith graphs. The Voith position control only look good when compared to some other system that was worse. A Chinese professor told me it was because the pumps become inefficient at low flow. It seems to me these hybrid actuators competes more with the Exlar type of electric actuators only it uses hydraulics instead of gears to convert rotational to linear motion. Energy costs must be high to justify the extra cost to get a pay back.
I was at a small trade show in the US. Finally people are talking about servo pumps here. Although I know there have been a few people that have done servo pump control in the last 10 to 12 years it is hard to convince people to put the extra effort into making such a system. Few want to even put a pressure transducer on the output of the pump in an effort to keep the pressure constant without the use of a big accumulator. Few ( <1% ) want to use the instantaneous calculated flow requirements from the motion controller to provide a feed forward control to the pump so the pressure doesn't need to drop. Some assembly is required. Pumps are not equally efficient over the whole range of flows. Some programming is needed to optimize efficiency.
I have known how do to this for years. I/we don't integrate systems and it has been ALMOST impossible to get others to try these advanced techniques.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
http://forum.deltamotion.com/
RE: Trends Seen from Trade Shows
Mike Halloran
Pembroke Pines, FL, USA
Behind is not good. It is hard to compete from behind.
Peter Nachtwey
When I was at a MSOE seminar 4 years ago I talked to one of the professors about how fast the motor can respond. He indicated that it can be quite quickly but there is a limitation if the motor/pump combination is just sucking oil out of the tank. There must be enough net positive suction head, NPSH, to avoid cavitation or the motor must be limited so it doesn't accelerate too quickly.
The Voith CLDP ( closed loop differential pump ) has this problem licked because the accumulator is also the tank or oil reserve so the intake of the pump always has enough pressure.
Peter Nachtwey
