Problem debugging the NXOpen code.
I am new to this NX Automation and I am stuck up with debuggingsad. I have created a NXOpen Project in "VS Express 2012 for Desktop" and written some code. I have build the code and the created dll works fine in NX when executed.neutral I want to debugg the code for that I try to attach to process "ugraf.exe", but it shows error "Unable to attach to the process. The address is not valid for this context" (see image for reference).evil
Please help me out if anyone has faced same issues.smile
RE: Problem debugging the NXOpen code.
You need to attach ugraf.exe first and then launch NX from VS.
In VS open up Properties for your project. Go to the Debug tab and set Start External Program to your installed ugraf.exe.
Then when go Start from VS, it will launch (an attached) NX. If you put in a breakpoint it will then drop into VS.
Paul
Paul Turner
CAD & Process Engineer
Mastip Technology
Thanks Paul for your feedback. But I am not able to attach ugraf.exe. Also in VS properties in Debugging I have set command to ugraf.exe(i.e. $(UGII_ROOT_DIR)/ugraf.exe), but NX doesn't launch through VS when I debug from VS it gives same error as while attach to the process. I have attached image of error in my previous post.
Thanks and Regards,
Yashodeep
