Best Practice for Publishing Elements
In a given CATIA assembly, I have my master geometry in a part.
1) When publishing sketches, lines, and edges for other parts to use, should I publish into the master geometry part level or publish to the assembly level?
RE: Best Practice for Publishing Elements
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
What do do you mean by assembly level? At assembly level I activate a part and then extract geometry that I need from another part.
