T60 Overall(Block Diff) Protection Relay , Angle Winding Respect to ?
Hi frineds ,
I m starter for testing T60 relay.And I m not sure about setting of winding angles.I couldnt understand how to set.
I drawed it , can you explain that what angles should be set and why ?
Files are on attchment.
http://files.engineering.com/getfile.aspx?folder=3...
http://files.engineering.com/getfile.aspx?folder=d...
RE: T60 Overall(Block Diff) Protection Relay , Angle Winding Respect to ?
Can you give a clear example with CTs,like my drawing ?
Thanks muchly.
