Welded joint material properties.......
Does anyone have access to material properties for steel in the HAZ (heat effected zone) and filler weld material properties? I am trying to build a FEA model of fillet welded joints. I will have more information soon in another message. I am just curious if there is any resources available or an individual with such data?
RE: Welded joint material properties.......
Best regards - Al
http://www.battelle.org/our-work/consumer-industri...
Verity can be a module added to another FEA program, like fe-safe.
