SW Properties disappearing when saving dwg as PDF
Has anyone had issue with erratic (not all the time) occurrences when saving (maybe printing too, but for sure saving) a dwg as PDF where properties such as description are still existent in the dwg but they have been "emptied" and their value is blank? This then leads to the PDF not having these values since they were emptied apparently prior to the PDFing of the file.
Thank you in advance,
Mike
Mike
