Volatile organic compounds Thermal oxidation in the CO2 atmospere
I have a question that Volatile organic compounds (CH4, C2H4, etc Organic concentration is 800vol.ppm, Oxygen 2vol%) can be thermal oxidated in the co2 atomospere?
Reaction temp. is 350~400dC with CTO (Catalytic Thermal Oxidizer, Catalyst is from clariant.
I guess RTO(Regenration Thermal Oxidizer) can not treat this Volatile organic compounds in CO2 atomosphre.
That is why The organic gas concentration is above 500ppm in the RTO Outlet
RE: Volatile organic compounds Thermal oxidation in the CO2 atmospere
And catalyst Vendor Clariant Say 300~400 degC Temp.is OK.
Anyway I tried to heating up more high temp. up to 500 deg.C,
But The result is same.
The volatile organic Gas's composition is CH4 500pppm, C2H4 300pppm, O2 2%, Others CO2 Gas
My question is In low O2 (2vol%) and high CO2 (97% Over)Balance condition, Organic compounds can be oxidized ?
