Wind turbine & wind direction
How do these types of wind turbines maintain their face into the wind? No vertical stabilizer?
I've seen a lot of them lately turned away from the wind, just doing nothing. Why no tails?
It seems that if the wind blew on a 3blade arrangement, it would always want to turn in the direction of the two blade side and it would just swivel off the wind. If it managed to get going, the 2bladed side would change with 1/2 revolution and then it would want to swivel off to the other side. Do they simply swivel a little bit in one direction, then the other at half rev, then the other at a full rev? Seems like a little bit of a tail would help greatly with that. Surely the wind on the nacelle isn't going to be enough to keep them facing the wind. That doesn't look like much of a tail. Is it enough (at least in most case) to keep them heading into the wind?
RE: Wind turbine & wind direction
These suckers are slewed by a motor and pinion gear arrangement, controlled by a system that determines average local wind direction and speed. Rotors face upstream to avoid the problems with the tower/mast wake disturbance.
As for turbines not spinning, see http://www.greentechmedia.com/articles/read/why-ar...
Curtailment ... if you can't get it through the grid to where it's needed, no point in making it. Isn't a lot of power gen capacity in the US Midwest stranded power?
The 40% capacity factor for the best wind sites would be really good. I've found that as you increase the area of "the site" to an area as large as Spain, the capacity factor drops to 10-20%.
CR
CapX2020 alleviated a lot of that in the upper Midwest. In my locale, just 45 minutes north of the "Buffalo Ridge", this has been a hot topic for many years.
In general, the wind turbine "business" relies on the manufactoring and construction tax write-offs and government-mandated rebates and government-mandated "electrical favored buy-in" rates to even pretend to make a profit.
The wind turbine average capacity = 0.17 to 0.22. Meaning you have to build 6x to 5x wind turbines to get the rated nominal power output of 1 over a full year's service. But half the time, you are getting no power out at all.
A capacity factor of 17-22% percent is very low. If you go look up the EIA's yearly report on the LOCE (levelized cost of energy), you'll see the total cost of different forms of generation's all said and done cost, including fuel, maintenance, spinning reserves, everything. Wind generation is near competitive or is competitive in some regions against everything with the exclusion of natural gas.
Yes 12% (lowest yearly average over the total area of Spain) to 22% (higher yearly average over the same area) are low numbers, which is why wind turbines can compete with other forms of energy generation ONLY when they are located in areas where the local capacity factor is very high (say 35-40% or more to equal solar PV). Those areas are not as common as one thinks. Most of these already have wind turbines working there. What I have noticed explains that not all wind turbines are located on hilltops where winds are best. That is why, as you increase the area you analyze, the regional capacity factors drop to numbers so low. That is also something that the WTMA doesn't like to talk about. I made a detailed comment on their online magazine a few years ago, giving specific actual examples showing reducing capacity factors as area increases and they promptly removed the whole article.
Anyway, all of that indicates that many wind turbines have been built up on land with poor wind generating characteristics, probably only for the tax credits. Why else would you do it. I certainly would not put one up if I was only expecting to get a max 20% return on my nameplate capacity... during a very windy year. You need a really great hilltop, Cape Cod, or tax credits to make most of them work. Santa Ana winds don't blow anywhere near 40% of the time over a year.
That's pretty much exactly what's happening in this area. The wind farm companies are chasing government money, not wind.
