Testing the emergency depressurization system of a Diesel HDT unit
Has anyone experienced a test of the emergency depressurization system of a Diesel Hydrotreating unit (ULSD) with the objective to check orifice plate dimensioning and depressurization rates in an HDT unit about to shutdown (end-of-run) ? Is this a bad idea/proposal considering the risks involved ? Thanks for your comments.
RE: Testing the emergency depressurization system of a Diesel HDT unit
What risks are you anticipating? The purpose of ESD-1 is to eliminate the risks, not to generate them. If you suspect that ESD-1 cannot not be effectively executed, that is one big reason to evaluate the system and actually conduct the test.
Dejan IVANOVIC
Process Engineer, MSChE
Out of curiosity, any examples of the "somethings" you may have found during review that "could cause all hell to break loose"?
