Reciprocating compressor - discharge line check valve
Coleagues,
What is the best solution for check valve at reciprocating compressor discharge line? Now there is installed stopcheck valve 1500 lb, 6 inch, whith pressure seal. 20 MPa op.pressure, fluid is hydrogen, op. Temp is up to 80 celsius. What is the best check valve for this services? This valve has solid metal gasket as presdure seal, and is problematical due to leakages. Is better solution to use jacketed (graphite core is covered with ss thin plate) pressure seal?
RE: Reciprocating compressor - discharge line check valve
Point #2, A Reciprocating Compressor is a piston oriented "positive displacement" (PD) vapor mover. A PD Pump normally does not need a Check Valve.
Here is another internal (Recip Comp) Check Valve.
ahUKEwiF4PHRqLXPAhVLJx4KHWgUBoYQsAQIHQ#tbm=isch&q=Images+of+Reciprocating+Compressor+Check+valves&imgrc=Fha8DjttiHgYDM%3A
http://www.hoerbiger.com/upload/file/check_valves_...
Interesting point, but I have never seen a reciprocating compressor (or a screw compressor, also PD, for that matter) installed in industrial service without a skid-level discharge check. Not one in thousands of compressor installations. They are so ubiquitous that I've never questioned why they are there. I'm going to have to think about this some more.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
