Source for Heat Transfer Coeficients
When I was in school, my number one question to the professor was always, "Great, I understand the physics, but in the real world, where do these givens come from?" The answer was always, "The company you work for will have the charts and tables of empirical they prefer you to use." Even many text books that provide sample tables have this kind of disclaimer.
Here I am, 12 years out of school, and after working at three different companies, I've found that this is almost never the case.
Currently I am working on a heat balance between tanks which contain combinations of water, fuel, and air. The tank walls are steel and coated. The application is fairly low risk and I am only trying to "ball park it," within, say, about 20%. For preliminary calculations, I am using overall heat transfer coefficients from various plate exchanger manufacturers which seems to match some other online sources for general air-steel-water coefficients. The coatings, of course, are a big unknown and the coating manufacturer does not seem to produce this data.
Can anyone recommend a reference for various overall heat transfer coefficients?
Thanks in advance for any assistance.
RE: Source for Heat Transfer Coeficients
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good Luck
Araza
Asif Raza
