Med/High Visc - PD pumps PSV's Inlet outlet DP's too high per typ. API forms. - always likely?
I'm revaliding a PHA for a med/high (100-500cp) plant.
We are going through the cases and taking credit for the positive displacement pumps spill back valves for preventing down stream vessel damage in a lock in case.
The problem I encounter is that almost all of them on the high viscosity cases exceed (by a margin) the inlet and outlet DP cases .
Inlet Dp's range from 12%upto 78% , with outlet DP's a similar range of 21 to 78%. Unfortunately the plant is very old (ish) 1980's vintage, I don't believe the fluid conditions have changed so is there a different standard to spill back pumps I'm not aware off.
"back in the day" did vendors/ engineers not calculate this stuff... I doubt it ".. I know different codes apply. but I'd like to get some experienced engineers background.
RE: Med/High Visc - PD pumps PSV's Inlet outlet DP's too high per typ. API forms. - always likely?
You describe this as a "spill back valve" so I don't know exactly what type valve you have. It could be (1) a modern liquid trim PRV, (2) an old style PRV, prior to advent of liquid trim, or (3) a fully modulating liquid service valve like a Fulflo. If the answer is #3 then I don't think you need to be concerned.
When you have a high viscosity fluid, it's often impossible to get the inlet losses to 3% or less. Sensitivity to inlet pressure loss started in the mid 90's with the implementation of OSHA PSM. The irony is that today we recognize that the 3% rule is inadequate for predicting chatter.
