Design Code/Standard of Circulating Fluidized Bed Gasifier
I am trying to make Equipment Specification document of gasifier (circulating fluidized bed) as part of FEED project (coal gasification power plant).
Now, I am confused to search which code/standard would suit the best to this equipment. Its pressure is about 7 psig, 850 deg C temperature. I was going to use ASME BPVC Section VIII but it is for pressure vessel >15psig.
What standard shall I use to this gasifier?
RE: Design Code/Standard of Circulating Fluidized Bed Gasifier
