Drafting Components Issue - Dimensions Hidden
Thank you in advance: I have a .stp file that I imported into what we call a "seed" file, which is we have a title block for our customer set up. We then import the .stp file. This particular .stp file includes 24 different components. I put each component on its own layer in order to draft each component. When I select, for example, Linear Dimension, I select both points, then the dimension shows, I click for placement, and the dimension disappears. Same thing when I try to create a Center Mark, it takes me through the steps, but the Center Mark does not appear.
Are the dimensions being placed, or what am I doing incorrectly?
Brent
Brent
RE: Drafting Components Issue - Dimensions Hidden
www.nxjournaling.com
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (29versions)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
