Installing a Force Main inside a larger pipe/sleeve
I need to run a small (2") sewage force main up a new 600' private subdivision road. If the Town has an issue with the FM being above the water main could I offer to sleeve the FM in a larger pipe for the run? Would the extra space inside the sleeve leave too much room for the pipe to move around while the pump is running and possibly cause a break that wouldn't have occurred if it was direct buried?
Greg
Greg
RE: Installing a Force Main inside a larger pipe/sleeve
I'm not sure this is allowed in most of the US, though, even encased.
You will need to contact the water and sewer agencies in the project area to determine their requirements. The typical requirement for horizontal separation is 10 feet.
ftp://www.ilga.gov/JCAR/AdminCode/035/035003700C03...
