Thermal Oil System
Thermal Oil System
Thermal Oil System
Does anyone have a diagram of a Thermal Oil System that can share please? also can anyone share his opinion on the advantages over steam systems for a Power Plnat?
http://albanesmolina.wix.com/home
RE: Thermal Oil System
Contact Dow, Therminol, Paratherm, Duratherm, etc. They provide heat transfer fluid tech support for potential and existing customers.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Generally speaking, thermal efficency is much better with a steam system than with thermal oil for power recovery applications. For heat energy tranfer operations, condensing steam heat transfer coeff is much better than that for hot oils.
