Brittle Fracture on Tensile Ti GR12
In reviewing a PQR, I notice one of the two tensile tests is reported to have a brittle fracture in the weld metal, both fail in the weld metal. Min tensile stress for this material is 485 MPa the tests results are 650 and 696 MPa (the brittle one). Both side bends are reported as being ok. No hardness tests have been carried out.
My question, is one brittle break in a tensile grounds to reject the weld test coupon? I have read through QW-150 and it is not addressed. I am learning towards yes as clearly a brittle micro structure is not a desirable material property for my application.
RE: Brittle Fracture on Tensile Ti GR12
