Part Families in NX10.0 can't be saved
I met some problem with NX's part family spreadsheet. It's OK to create spreadsheet, and also to verify the part Number. But when you wanna create part or save family. It doesn't work and stop the program. After several minutes, it shows error info. Please see attached pic.
It would be appreciated if you supply the solution for this. Thanks in advance.
Best regards,
Neil
Neil Lu
Mechanical Design Engineer
Moog Control System Ltd
NX10.0 / TC11
Dell Precision 5510 Intel(R) Xeon(R) CPU E3-1505M v5 @ 2.80GHz 2.80GHz, 16 Gb Win7 64B
Nvidia K1100M 2048 MB DDR5
RE: Part Families in NX10.0 can't be saved
Can you tell about the Part family save directory location?
regards,
Mathi Krishnan
NX10.0.2.6
Did you check your NX Logfile? Any detailed description of the issue in there?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
What version of Excel are you using, and is it the version that Siemens has certified to work with NX 10?
www.nxjournaling.com
