Lead-free chrome-plated brass ball valve
Is the industry moving away from lead-free chrome-plated brass ball valves for domestic water systems?
As there was some confusion during a conversation with one supplier, I am referring to the ball being chrome-plated, not the valve body.
A Brand-X supplier said they stopped making them because chrome is not lead-free.
A Brand-Y supplier said when they say "chrome-plated," they actually mean "nickle-plated." And they claimed everyone else uses this terminology.
That is contrary to what I see here:
http://www.valvemagazine.com/web-only/categories/t...
"Chromium carbide gives a Rockwell scale (Rc) hardness of about 65 and resists erosion and extreme temperatures."
So what is reality for domestic water valves in a commercial/institutional project?
- Is the chrome plating not lead-free?
- Do all the manufacturers tell us fiction when they use "chrome-plated" as code for "nickle plated?"
RE: Lead-free chrome-plated brass ball valve
Under pressure, they may provide cut sheets or other documentation, which can usually be trusted, after cross-checking that you are looking at the correct document for the correct product.
Mike Halloran
Pembroke Pines, FL, USA
We still specify chrome plated for non lead free versions.
Chrome plating and nickel plating are different finishes.
Contact the manufacturer directly for technical information.
