Hazen Williams Equation and Minor Losses
I have a question concerning the Hazen Williams equation for determining Head Loss. Is there any way to figure minor losses such as the losses that occur at valves and fittings? Or does Hazen Williams only calculate major losses in pipes?
RE: Hazen Williams Equation and Minor Losses
Ashtree
"Any water can be made potable if you filter it through enough money"
That being said, I think the answer to this question (like so many others on these forums, as can probably be gleaned from some learned references in this field) is "it depends" i.e. on the designer, experience and intent. I think some designers ignore minor losses for at least some purposes, maybe with a little lesser value of "C" coefficient than if it were all straight pipe in a flow laboratory (knowing there could be a few fittings there, or added in construction to get around previously unknown obstacles in the field, and some also similarly do calculations for some purposes not necessarily with the actual inside diameters of various pipes but instead with simplification to "nominal" diameters for flow calculations.
In any case, I think rigor is in general good, and one area where one really should look very closely at minor losses and also size of pipe selected minor losses is probably in pump suction piping where head loss among other things is very critical to proper performance and efficiency, and there also might be a good many fittings, valves and specials etc. in relatively short lengths of pipe.
