Removing selection Stickiness from a Recorded NX Journal to "Add bend lines on Flat Pattern vie
I need help removing selection Stickiness from a Recorded NX Journal to "Add bend lines on Flat Pattern view in NX Drafting". Below is my recorded Journal Code for selecting that view and add bend lines through flat pattern setting. I want user to select the view using an UI and automatically add bend lines on that view selected by user. Need help modifying this code below. Thanks in advance.
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: Edit->Style...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
theSession.SetUndoMarkName(markId1, "Class Selection Dialog")
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Class Selection")
theSession.DeleteUndoMark(markId2, Nothing)
theSession.SetUndoMarkName(markId1, "Class Selection")
theSession.DeleteUndoMark(markId1, Nothing)
' Dialog Begin View Style
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "View Style")
Dim baseView1 As Drawings.BaseView = CType(workPart.DraftingViews.FindObject("FLAT-PATTERN#1@18"), Drawings.BaseView)
Dim flatPatternSettings1 As SheetMetal.FlatPatternSettings
flatPatternSettings1 = baseView1.Style.FlatPattern.GetPropertiesObject()
Dim displaydata1 As SheetMetal.FlatPatternSettings.FlatPatternObjectTypeDisplay
displaydata1.Type = SheetMetal.FlatPatternSettings.FlatPatternObjectType.BendUpCenterLine
displaydata1.IsEnabled = 1
displaydata1.Color = workPart.Colors.Find("Background")
displaydata1.Font = ViewDependentDisplayManager.Font.Dashed
displaydata1.Width = -1
flatPatternSettings1.SetFlatPatternObjectTypeDisplay(SheetMetal.FlatPatternSettings.FlatPatternObjectType.BendUpCenterLine, displaydata1)
Dim displaydata2 As SheetMetal.FlatPatternSettings.FlatPatternObjectTypeDisplay
displaydata2.Type = SheetMetal.FlatPatternSettings.FlatPatternObjectType.BendDownCenterLine
displaydata2.IsEnabled = 1
displaydata2.Color = workPart.Colors.Find("Background")
displaydata2.Font = ViewDependentDisplayManager.Font.Dashed
displaydata2.Width = -1
flatPatternSettings1.SetFlatPatternObjectTypeDisplay(SheetMetal.FlatPatternSettings.FlatPatternObjectType.BendDownCenterLine, displaydata2)
baseView1.Style.FlatPattern.Commit()
baseView1.Commit()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
FJ
RE: Removing selection Stickiness from a Recorded NX Journal to "Add bend lines on Flat Pattern vie
If you want the bend lines on your flat pattern views, consider changing your template files and/or customer defaults so that they are included when the view is created.
That said, below is some code to add a selection function to your journal:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "flat pattern view settings")
        lw.Open()
        Dim selectedView As Drawings.BaseView = Nothing
        If SelectBaseView(selectedView) = Selection.Response.Cancel Then
            Return
        End If
        flatPatternSettings1 = selectedView.Style.FlatPattern.GetPropertiesObject()
        displaydata1.Color = theSession.Parts.Work.Colors.Find("Background")
        displaydata2.Color = theSession.Parts.Work.Colors.Find("Background")
        selectedView.Style.FlatPattern.Commit()
        selectedView.Commit()
        lw.Close()
    End Sub
    Function SelectBaseView(ByRef selObj As TaggedObject) As Selection.Response
        Dim title As String = "Select flat pattern view"
        Dim prompt As String = "Select flat pattern view"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_view_type
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt,
        title, scope, selAction,
        includeFeatures, keepHighlighted, selectionMask_array,
        selObj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Thanks cowski, this worked perfectly.
FJ
