External Pressure Chart for SA-537 Thickness 64 mm and less
Hello everyone! May I please have some clarity on following??
External pressure chart referred in Table-1A for SA-537 Gr.1 (t<=64mm) is CS-3. And somehow, there is separate Chart for SA-537 Gr.1 (t<=64mm)as CS-4. Can somebody educate me how and why so?
RE: External Pressure Chart for SA-537 Thickness 64 mm and less
Any clarifications on this please???
This would appear to be an error.
Please see the section in II-D titled "SUBMITTAL OF TECHNICAL INQUIRIES TO THE BOILER AND PRESSURE VESSEL STANDARDS COMMITTEES". Follow the instructions on preparing an inquiry. The on-line tool is very efficient.
Thank you so much for your response TGS4.
I shall do the needful and update the conclusion here.
I am also on the opinion the it's a mistake.
