Delete curve in assembly
Hi all,
Don't know if this is possible but i have an assembly and used assembly cut, and synchronous modelling, i have 'deleted' the face of a hole but i am stuck with the 'thread' curve, is there any way i can delete this curve within the assembly as it is no longer needed, or is my only option to 'hide' them?
James
James
RE: Delete curve in assembly
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
The reason for doing it this way is because i have 2 similar components, part A and part B, the difference between them is that part B has less holes but uses the same base as part A but they need to be updated together, so instead of having 2 separate model they both work of part A model and then i use synchronous modelling on part B to remove the un-needed holes. Does that make sense?
James
Open the detailed part file and then edit the Reference Set and explicitly deselect the offending curves. In that way, they should not appear when the Component part if added to an Assembly as long as you use the Reference Set that you just edited/updated.
Irvine, CA
Siemens PLM:
UG/NX Museum:
