EPAnet Problem
EPAnet Problem
Good Morning,
I hope you all are fine. I am working on EPANet and the problem i am facing is that i want to use google earth map or GIS map of high resolution as a back drop of my water network. But EPANet is unable to do so. Need help.
Thanks in advance
Thanks in advance
RE: EPAnet Problem
insert the backdrop
then calibrate a distance to the map
If you want this feature in a more easy to use format, you will have to buy one of the paid for programs from the various companies that sell network solution programs
Hydrae
