Creating a pattern in an Assy without a hole pattern
I use Inventor quite a bit, and in that you can create a pattern that you could select a part, let's say a support beam between two parts... and tell it to pattern that beam 10 times, with 20mm in between each one.
Is this possible in Edge? I know you can pattern things like hardware to holes, but that's not what I'm trying to do.
RE: Creating a pattern in an Assy without a hole pattern
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
