nx cam - cavity mill, change direction of tool path from clockwise to counter clockwise
Hi Guys,
first I am not sure if I am using the correct operation so let me know if there is a better way.
I am facing the outside edge of a part all the way round. I am using a cavity operation with cut pattern 'follow periphery' and leave stock for a finish cut. All works but I would like to reverse the direction of the toolpath which is presently in a clockwise direction and conventional milling. Instead I would like the toolpath to go in the counter
clockwise direction around the part thus climb mill - how do I do this?
many thanks,
James
nx10
many thanks,
James
nx10
RE: nx cam - cavity mill, change direction of tool path from clockwise to counter clockwise
John Joyce
Manufacturing Engineer
Senior Aerospace CT
NX 10 Vericut 7.4.1
yes, climb cut is set correctly... thanks!
You may not be interpreting the cut direction the same as the system. For example, for follow peripheral with an inward pattern direction, the path would be clockwise to climb cut, because the system things you are removing material on the inward side of the pattern.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
exactly correct. Many thanks, I understand now...
cheers,
James.
