EDIT OBJECT DISPLAY: APPLY CHANGES TO OWNING PART
Hi to all,
Whenever I want to change the color of a component in an assembly I access to "Edit object display".
Normally, I want to the change the color in both files, into the part and into the assembly.
For that, I use the setting "Apply changes to owning part".
The problem is that sometimes I can´t check this setting because it´s in grey (deactivated).
Someone knows why sometimes I can use it and others I can´t. What I´m doing different??
Thanks in advance!
Thanks in advance!
Airin
NX Designer
RE: EDIT OBJECT DISPLAY: APPLY CHANGES TO OWNING PART
the option you want will be activated
NX 7.5 64bit
NX 9.0.3.4 MP4 64bit
NX 10.0.3.5 MP3 64bit
www.studiotreccani.com
It works :)
Airin
NX Designer
i.e
Component
face
face-n
Solid body
Except the component object , the apply changes to parent part should appear on all.
Tomas
