Can someone tell me what this valve is?
I was wondering if anyone could tell me what this valve is and what its used for? As far as I can tell it's some kind of solenoid operated valve, but that's about all I can figure with my limited knowledge. It looks pretty specialized so its got me curious. Anything you guys could tell me would be great!
RE: Can someone tell me what this valve is?
At least do a search for each of the model numbers on the tags; we can't see them in your image.
Come back if you still have questions _after_ doing a little of the work for yourself.
Mike Halloran
Pembroke Pines, FL, USA
CETOP 7 or NG size 16.
Pressure reducer and relieving valve in the middle and a linear transducer on the main spool to measure the position.
http://www.eaton.com/ecm/groups/public/@pub/@eaton...
