NX Journal - List of T problem
Hello everyone,
Some time ago I have created journal to report broken links. Link Because this thread is closed, I start this one. Now I would to add broken link to list, sort them and display. Below is my code:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Collections.Generic
Public class PList
	'Implements IEquatable(Of PList)
	Public Property Part_Name As String
	Public Property Link_Name As String
	Public Property Parent_Name As String
	Public Sub New()
	End Sub
	Public Sub New(ByVal PartN As String,
			ByVal LinkN As String,
			ByVal ParentN As String)
	Part_Name = PartN
	Link_Name = LinkN
	Parent_Name = ParentN
	End Sub
End Class
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Dim theUfSession As UFSession = UFSession.GetUFSession
    Dim sourceTag As Tag
    Dim linkBroken As Boolean = True
    Dim workPart As Part = theSession.Parts.Work
    Dim dispPart As Part = theSession.Parts.Display
    Dim PartList as New list (of PList) ()
    Sub Main()
    lw.Open
    Try
        Dim c As ComponentAssembly = dispPart.ComponentAssembly
	if not IsNothing(c.RootComponent) then
            ReportComponentChildren(c.RootComponent, 0)
        else
            lw.WriteLine("Part has no components")
        end if
    Catch e As Exception
        theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
    End Try
    Partlist.sort
	for each Czesc as PList in Partlist
		lw.writeline("Part Name:" & Plist.Part_name)
		lw.writeline("Name: {0},{1},{2}" PList.Part_Name, PList.Link_Name, PList.Parent_Name)
	next
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, _
        ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
	    If LoadComponent(child) Then
	Dim MyPart As Part = child.Prototype.OwningPart
	Dim sourceTag As string
	Dim Parentname as string
	   For Each theFeature as Features.Feature In MyPart.Features
            If theFeature.FeatureType.Contains("LINKED") Then
               theUfSession.Wave.IsLinkBroken(theFeature.Tag, linkBroken)
                If linkBroken Then
			theUfSession.Wave.AskbrokenLinkSourcepart(theFeature.Tag, Parentname, sourceTag)
					if not Partlist.contains(child.name, theFeature.GetFeatureName,Parentname)
then
	Partlist.add(new PList(child.name, theFeature.GetFeatureName,Parentname))
					end if
		end if
           End If
        Next
            Else
                'component could not be loaded
            End If
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
 Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin,
csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
			msgbox(theloadstatus.getstatus(i))
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            lw.WriteLine("Nie znaleziono pliku")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
            Catch ex2 As NXException
		if ex2.message = "File not found" then
	                lw.WriteLine("Błąd: " & partname & "   " & "Nie znaleziono pliku")
		else
	                lw.WriteLine("Błąd: " & partname & "   " & ex2.Message)
		end if
                Return False
            End Try
        Catch ex As NXException
            'unexpected error
            lw.WriteLine("error: " & ex.Message)
            Return False
        End Try
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
I receive several errors:
* Line 76 - lw.writeline("Part Name:" & Plist.Part_name) -> Reference to a non-shared member requires an object reference
* Line 77 - lw.writeline("Name: {0},{1},{2}" PList.Part_Name, PList.Link_Name, PList.Parent_Name) -> Too many arguments in element "Public sub writeline(msg as string)" I used this page for example: Link
* Line 105 - if not Partlist.contains(child.name, theFeature.GetFeatureName,Parentname) then -> Can't convert value type string to PList
* Line 105 -> Too many arguments.
Any suggestions how to solve it?
With best regards
Michael
RE: NX Journal - List of T problem
CODE
	lw.writeline("Part Name:" & PlistCzesc.Part_name)
	lw.writeline("Name: {0},{1},{2}" PListCzesc.Part_Name, PListCzesc.Link_Name, PListCzesc.Parent_Name)
next
CODE
lw.writeline("Name: " & PList.Part_Name & ", " & PList.Link_Name & ", " & PList.Parent_Name)
The NX listingWindow's .WriteLine method does not support string substitution like the console's.
The Partlist object contains Plist objects, not strings. The following link shows one way to find an object with a particular property value in a list:
https://msdn.microsoft.com/en-us/library/x0b5b5bc(...
This error is related to the one above.
www.nxjournaling.com
Thanks Cowski,
I fixed the code, so the errors doesn't show. Now I have two problems:
First, sort doesn't work. I thing because there is more elements in one line
Second, my exception from adding to list is broken, so even if element is on list, it add another one.
CODE
if not partlist.contains(New PList() with { _
		        .Part_Name = child.name, _
			.Link_Name = theFeature.GetFeatureName }) then
		end if
I have to figure out something else.
With best regards
Michael
The sort function does not work because the computer doesn't know how you want your custom objects sorted; you will need to write some code to tell it how to sort your objects.
http://www.nxjournaling.com/content/sort-list-nx-o...
There are multiple ways to solve the 2nd problem. One easy way would be to maintain a separate list of the components that you have processed so far. This could be a string list that holds the component name (or perhaps the component file path would serve better); as you process the assembly components, you can check this list and easily skip the ones already processed.
Thank again Cowski.
I found this page about sort elements in list, and used it. Link
Below is my final code, maybe it will be useful for someone else.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Public class PList
	Part_Name = PartN
	Link_Name = LinkN
	End Sub
End Class
Module NXJournal
    Dim List1 as New List (of String)
     Sub Main()
    lw.Open
    Try
            ReportComponentChildren1(c.RootComponent, 0)
        else
        end if
    End Try
	if Not IsNothing(Partlist) AndAlso Partlist.Count > 0 Then
		'Partlist.sort(Function(x, y) x.part_name.CompareTo(y.Part_name))
		partlist.sort(AddressOf Comparer)
		lw.writeline(" ")
		lw.writeline("Parts with broken links:")
		lw.writeline(" ")
		lw.writeline("---------------------------------------")
		lw.writeline("| Part name | Link name | Parent name |")
		lw.writeline(" ")
			lw.writeline(czesc.Part_Name & "| " & czesc.Link_Name & "| " & czesc.Parent_Name)
		next
	end if
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, ByVal indent As Integer)
	Try
		if child.IsSuppressed = true then
			lw.writeline("Error: " & child.DisplayName & ".prt" & "   " & "Part is suppressed")
			Continue for
		end if
			Catch e1 As Exception
		        theSession.ListingWindow.WriteLine("Failed: " & e1.ToString)
		end try
            Else
            End If
            reportComponentChildren(child, indent+1)
        Next
    End Sub
    Sub reportComponentChildren1( ByVal comp As Component, _
	Try
			'lw.writeline("Error: " & child.DisplayName & ".prt" & "   " & "Part is suppressed")
			Continue for
		end if
			Catch e11 As Exception
		        theSession.ListingWindow.WriteLine("Failed: " & e11.ToString)
	end try
                If linkBroken Then
				'lw.writeline(child.name)
				if not list1.contains(child.name) then
					list1.add(child.name)
				end if
		end if
           End If
        Next
            Else
            End If
            reportComponentChildren1(child, indent + 1)
        Next
    End Sub
Private Function Comparer(ByVal x As Plist, ByVal y As Plist) As Integer
	Dim result As Integer = x.Part_name.CompareTo(y.Part_name)
	If result = 0 Then
		result = x.Link_name.CompareTo(y.Link_name)
	End If
	Return result
End Function
        Try
            Else
            End If
            Return True
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin, csysMatrix, transform)
                        Else
                            lw.WriteLine("File not found")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        Return False
                    End If
                Else
                    Return True
                End If
	                lw.WriteLine("Error: " & partname & "   " & "File not found")
		else
	                lw.WriteLine("Error: " & partname & "   " & ex2.Message)
		end if
                Return False
            End Try
            'unexpected error
            Return False
        End Try
    End Function
    End Function
End Module
With best regards
Michael
I have made changes in journal - export XT. I added list of components which was already processed. I found out, if component is used more than once, then it's not processed. I tried changing code, but with no results. Any help will be welcome.
Here is my code:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Dim filename as string
    Dim poz as string
    Dim Parentdir as String
    Dim TimeNote As string
    Dim list as New List (of string)
    Dim list2 as New List (of string)
    Sub Main()
    TimeNote = System.DateTime.Now.Tostring("yyyy.MM.dd")
    lw.Open()
    Try
            ReportComponentChildren2(c.RootComponent, 0)
        else
            lw.WriteLine(workpart.leaf & ".prt ->" & " Part has no components")
        end if
    End Try
	If Not IsNothing(lista) AndAlso list.Count > 0 Then
	lw.writeline(" ")
	lw.writeline("----------------------------------------------------------------------------------------------- ")
	lw.writeline("POSITION IS NOT SET:")
	lw.writeline(" ")
	lista.sort
		for each alista as string in lista
			lw.writeline(alista)
		next
        End If
	If Not IsNothing(lista2) AndAlso list2.Count > 0 Then
	lw.writeline(" ")
	lw.writeline("EXPORTED PARTS:")
	lw.writeline(" ")
	lista2.sort
		for each alista2 as string in lista2
			lw.writeline(alista2)
		next
        End If
    lw.Close
    End Sub
	Try
			lw.writeline("Błąd: " & child.DisplayName & ".prt" & "   " & "Part is suppressed")
			Continue for
		end if
		end try
            Else
            End If
        Next
    End Sub
    Sub reportComponentChildren2( ByVal comp As Component, _
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim tagList() As NXOpen.Tag
	Dim exportFileName As String = Nothing
	Dim exportFileName1 As String = Nothing
	Dim nazwa as string
	Dim path As String
	Dim PSversion as integer = 240
	Dim layerNumber as Integer = 1
	Dim i As Integer = 0
	Dim theBodies As New List(Of Body)
	Dim inx As Integer = 0
	Dim theBodyTags as New List(Of Tag)
		theBodyTags.clear()
		Try
			Continue for
		end if
		end try
	        filename = child.DisplayName()
		try
			poz = child.GetStringAttribute("poz")
				if poz = "" then
					if not list.contains(child.name) then
						list.add(child.name)
					end if
				end if
                	Catch ex21 As NXException
                    		If ex21.ErrorCode = 512008 Then
					if not lista.contains(child.name) then
						lista.add(child.name)
					end if
					myPart.SetUserAttribute("Poz", -1, "", update.option.now)
				Else
		                        lw.WriteLine("error: " & ex21.ErrorCode & ", " & ex21.Message)
				end if
		end try
			'MsgBox("Number of characters is: " & TextLength)
        	If isNumeric(poz) Then
			if (poz > "000") and (poz < "351") then
				theBodyTags.clear()
				  if not list2.contains(child.name) then
					list2.add(child.name)
						For each tempBody as Body in mypart.Bodies
				 	  		if tempBody.Layer = 1 then
				 	   		   theBodytags.Add(tempBody.tag)
							end if
						Next
						if theBodyTags.Count = 0 then
							'lw.writeline(Mypart.leaf & ".prt -> No bodies to export")
	    						'exit sub
							'return
						end if
				'end if
			end if
		exportFileName = myPart.FullPath
        	nazwa = myPart.Leaf
		parentDir = System.IO.Directory.GetParent(exportFileName).FullName
		parentDir = System.IO.Directory.GetParent(Parentdir).FullName
		'path = IO.Path.Combine(IO.Path.GetDirectoryName(myPart.FullPath), "step")
		path = parentdir + "\Parasolid"
		If(Not System.IO.Directory.Exists(Path)) Then
    			System.IO.Directory.CreateDirectory(Path)
		End If
		exportFileName = IO.Path.Combine(path, nazwa & ".x_t")
	  	     'if this file already exists, delete it
       		If My.Computer.FileSystem.FileExists(exportFileName) Then
	           My.Computer.FileSystem.DeleteFile(exportFileName)
	        End If
       Dim numUnexported As Integer
       Try
       ufs.Ps.ExportLinkedData(theBodyTags.ToArray, theBodyTags.Count, exportFileName, PSversion, Nothing, numUnexported, Nothing)
           lw.WriteLine("*** ERROR ***")
           lw.WriteLine(ex.ErrorCode.ToString & " : " & ex.Message)
       End Try
		end if
  	 end if
            Else
            End If
            reportComponentChildren2(child, indent + 1)
        Next
    End Sub
        Try
            Else
            End If
            Return True
             Try
                        Else
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        Return False
                    End If
                Else
                    Return True
                End If
	                lw.WriteLine("Błąd: " & partname & "   " & "File not found")
		else
		end if
                Return False
            End Try
            'unexpected error
            Return False
        End Try
    End Function
    End Function
End Module
With best regards
Michael
The code tries to make use of variables named lista and lista2, but I don't see where these list variables are declared.
Hello Cowski, I translate my code to english, that's why there was some errors in names of lists.
Here is code without errors:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Dim poz as string
    Sub Main()
    lw.Open()
    Try
        else
        end if
    End Try
	If Not IsNothing(list) AndAlso list.Count > 0 Then
	lw.writeline(" ")
	lw.writeline(" ")
	list.sort
		for each alist as string in list
			lw.writeline(alist)
		next
        End If
	If Not IsNothing(list2) AndAlso list2.Count > 0 Then
	lw.writeline(" ")
	lw.writeline(" ")
	list2.sort
		for each alist2 as string in list2
			lw.writeline(alist2)
		next
        End If
    lw.Close
    End Sub
	Try
			Continue for
		end if
		end try
            Else
            End If
        Next
    End Sub
	Dim nazwa as string
	Dim path As String
		theBodyTags.clear()
		Try
			Continue for
		end if
		end try
		try
				if poz = "" then
					end if
				end if
					end if
				Else
				end if
		end try
				theBodyTags.clear()
							end if
						Next
	    						'exit sub
							'return
						end if
				'end if
			end if
        	nazwa = myPart.Leaf
		End If
	        End If
       Try
       End Try
		end if
  	 end if
            Else
            End If
        Next
    End Sub
        Try
            Else
            End If
            Return True
             Try
                        Else
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        Return False
                    End If
                Else
                    Return True
                End If
		else
		end if
                Return False
            End Try
            'unexpected error
            Return False
        End Try
    End Function
    End Function
End Module
With best regards
Michael
The problem is here:
CODE
				theBodyTags.clear()
							end if
						Next
	    						'exit sub
							'return
						end if
				'end if
			end if
If I remove those two lines:
CODE
It's working good.
With best regards
Michael
