Custom 1/4in Mono Audio Jack
Hi to all,
basiclay im looking for a component that looks and functions like the 1/4in mono oudio jack but with a stright flat end and not tear shaped (so it'll look like the rod next to the jack in the photo).
Was wondering if something like that evailble as off the shelf part or i have to make a custom part (or any other suggestions)?
Thanks.
Thanks.
RE: Custom 1/4in Mono Audio Jack
What you've described already won't align with the socket nearly as easily as the standard jack plug does (because you've eliminated the pointy tip) and won't be retained in the socket as effectively (because you've eliminated the shoulder that does that job).
What do you want to do with this thing? Do you still need the tip to be electrically insulated from the body (for that matter, does the thing need to be electrically conductive at all)? Maybe what you need is a 1/4" pip pin.
If you're struggling to find someone that sells "something a bit like ...., but different in this, that, or the other way", it's sometimes easier to ask "what do people use to do this job - and where do they get it?"
A.
First of all i need the conductive properties of the jack to be retained i.e. 2 insulated conductive parts (for a positive and negative poles).
I don't need the tear shaped tip for retention, i need it to be flat, something that resembles more to the pip pin tip.
Basically i want for the jack to be in the shape of the small tube (as shown in the photo next to the jack), the tube is a blasting cap and im working on a training device where instead of the blasting cap the jack will be inserted in its place and close an electrical circuit (hence the need for the 2 insulated from each other but conductive parts) to indicate that the device is armed.
The prototype is working fine with the jack as is, but the company that ordered the training device insisting that whatever replaces the blasting cap will be exactly the same shape and size, the size (length and Dia.) of both the cap and jack are the same but the tip is a problem.
So im looking for an 1/4" mono audio jack with a flat end.
