Thermic oil pump seal problem
All experts:
I'm having bit of a problem with my Thermic oil pump
It is a Dean model 4144 high temperature pump 3x4x8.5. The thermic oil is Therminol 72 with a maximum operating temperature of 380 Deg C and the pump has a John Crane mechanical seal model 609
There had been three cases when the seal totally crapped out completely and has to be replaced. Per John crane the seal was damaged by coking of thermic oil on the seal face which lead to its failure. This seems a little odd since the pump has been operating only for 2 months
I've tried to trouble the problem by operating the pump closer to BEP by maintaining proper differential pressure.
The pump was working fine with a thermic fluid temperature of 330 Deg C; I've tried to raise the temperature to 345 Deg C. The pump ran for a day without any issues and then started to leak very badly. The seal failed again
Any experiences with a similar and similar issues
Araza
Araza
Asif Raza
RE: Thermic oil pump seal problem
Ashtree
"Any water can be made potable if you filter it through enough money"
Asif Raza
Is the seal the right one for that application?
Ashtree
What about operating pressures? Are you within the limits of the seal?
Am i correct that the caking of the oil on the shaft was preventing the correct seating of the moving face, thus causing the failure to seal?
Ashtree
My operating pressure is optimal the discharge is only 100 psig
The caking is not on the shaft but on the seal face
Asif Raza
Ashtree
http://www.mp-gps.com/products/process-and-high-te...
Make sure that the finned section between the pump body and the seal, which is intended to allow the seal to stay cool, has not been insulated...
You listed the make and model of the seal but not the seal plan. The Dean pump used for thermal fluids uses a single mech seal, without a seal buffer fluid, so I'm not sure what your glycol is doing. If it is a pump with a double mech seal and a seal buffer fluid, then glycol is probably the wrong material to use as a buffer fluid in high temperature thermal oil service.
Are you sure the coking is happening on the seal? Or is there another item (i.e. a heater) which is causing the oil to coke?
More information will help the community answer your question better.
Johnny Pellin
I do not have steam in the plant. I only have cooling glycol and the chilled glycol
The pump has single mechanical seal without barrier fluid
The seal chamber is not exceeding 400 deg C
Asif Raza
