Resources (Books, Websites, PDF files, etc) needed to be a good Engineer at Pump manufacturer QRC
Hello Dear Engineers,
I recently started working as an Engineer, at a Quick response center of a big company that designs and manufactures pumps for oil and gas companies (like chevron, Valero, Tesoro, water districts, etc). We receive different types of pumps here, disassemble, clean, inspect and then recommend what our customers should do. It will either be repair, use the way it is after we clean it, buy a new pump, or upgrade the pump with some new parts. I don't have any past experience with pumps so I am a little struggling.
The main challenge for me is to recommend the customer what to do (use the way it is, repair, upgrade or buy a new pump). Here are the things I need help with
1)What are the processes for the repairing of impellers, shafts, bearings, couplings, mechanical seals, ball bearings, etc etc.
Like send it for spray a layer of oxide, etc??
2)In what condition, we need to buy a new part?
With the experience you have, can you please suggest me any book, link or other resource that I can use to learn the above mentioned things.
What will be your advice to me in this case?
RE: Resources (Books, Websites, PDF files, etc) needed to be a good Engineer at Pump manufacturer QRC
Likewise spend a bit of time working with those guys. Particularly if you have some old ornery guy who has been there for years and hates young punks who don't know anything telling him how things should be done. Fair chance he will know what you need to know, you just have to convince him that you want to learn.
Ashtree
"Any water can be made potable if you filter it through enough money"
Ask your boss if you can visit some of the end users using your pumps, again talk to the people actually using and maintaining the equipment- you will be surprised what knowledge there is to gain from end users - listen to any criticism of the equipment and learn from it.
Request that you work in the shop for 3-4 months to obtain the experience.
Here's another thing. When you face a challenging situation on a specific pump, take photos and post them with your thoughts/questions on a forum like this (with names of customers hidden). People tend to engage much more easily on specific cases than broad generalities. You will often find many different angles to look at the same problem. Then as you work through the problem post the results. The thread may end up being something of a mini case study that you can refer back to.
Just to get started touching the subject of shaft repair.
Shafts sometimes require straightening (if TIR is too large).
Shafts sometimes require buildup… there is a choice of processes. Rather than picking a process at random, look at what processes your shop offers or a local shop you trust offers.
When does shaft require buildup? If the seat for a rolling bearing has worn such that satisfactory fit is no longoer attainable. Look at bearing manufacturer's catalog and familiarize yourself with fit requirements. Similar may apply to the seat where impeller sits but I'm less familiar with that.
Rolling bearings - usually replaced instead of repaired unless they are very large (expensive).
Also customer's specifications may have some clues about what types of repairs are required or acceptable.
By writing four or five sentences about repair, I am not saying this comes close to answering anything.
Try to think through the cost of repair vs cost of new part; lead time of repair vs new part, and most importantly reliability of repair vs reliability of new part.
As a customer receiving a repair shops's recommendation, my questions will always fall along those lines.
(2B)+(2B)' ?
